so are tailgate switch problems common on this model of Jeep? the motor that releases the glass quit working a couple of days ago. and i had a couple of hours open today. so i thought i would look at it. so far (twice) i have been able to open the tailgate and glass by hand, working slowly so as to not stress the glass to much. the LAST thing i wabt to do is break the glass! so with my ADHD brain, the only way for me to fix things sometimes (i openly admit that electrical is my weakest skill) is to reverse engineer it. if i can understand it, i can fix anything. electrical things are just plain magic for the most part, and automatic transmissions are full blown voodoo! anyway, i worked my way thru the actual release motor and glass open sensor, and they work fine. so to me that leaves 2 things, d.c. power, or the switch on the handle. i verified power is getting back there, but that is where i had to quit. i was thinking about pulling the handle off to verify the switch is bad at dinner. and that's when it hit me. do these switches freeze and not work in the winter? it will be a LOT easier to point a hair drier at the switch for 10 minutes than it will be to remove the switch, and reverse engineer it. is this common? or am i grasping at straws?
