Rennagade
Did a google search and found that the part number is most likely... 05143017AA. $12.20 part. Hope this is the one.
yes that is kind of what was wrong with mine. your describing a open circuit with your switch. It should be open when you want the glass shut.
Mine was intermittantly closing the path through the switch causing it to randomly open or cycle the solenoid. like i was pulling on the handle
take the switch in your hand and depress it. if it works as advertised it wasn't making contact at the handle. If there is no change from unplugging it, go to your local dealer and order that switch. Sorry no part number.
If you have a DMM (digital multi meter, or analog, it really doesn't matter), put it across the connector to measure resistance [ohms]. open when not pressed. low (sub 10 ohms or practically zero) when pressed.
Not to the hijack the thread, So what should it read in ohms when testing the connector? No higher than 10?
