The "Liberator" Mini Build
Scottm2010
Lee's Summit, Missouri
Well, I had a shop do the front because that is what people recommended. But you can use just regular spring compressors, just be careful because there is a TON of pressure on that spring.
cplchris
Albany, NY
yea the more i think about it ill prolly go to a shop, unless i can get access to a spring compressor
cplchris
Albany, NY
scottm2010, what is your hub to fender measurements? i just installed the bds lift with jba ucas, no top plates and no extra isos, i havent had it aligned yet but my front hub to fender is about 23 inches and the rear is about 21 inches, jus wanna make sure i didnt f anything up
Boo
Canfield
I noticed your grille guard and it looks absolutley amazing on your kj (looks just like mine!) where did you get it?!?!
new jeep owner
New Brunswick Canada
what size Boilers shims? 1/4 or 3/8 I might look into doing this myself.
found a canadian distributor for BDS about two hours away :happy160:
did you do the clevis lift as well?
Scottm2010
Sorry I haven't been on here much.
My front is 21.5 inches and the rear is 22 inches... I don't know what you did. Haha
Thanks! It took some searching around to find it. I found it on one of the Liberty forums. Just search around on the for sale section and hopefully you can find something! :)
I have the 3/8 Boiler Shims.
Thanks for the complements!
