This is something I've wanted to do since I found out 4.10 gears existed for the KJ. With the hilly terrain in this area, the KJ has always seemed under powered. After putting the 245/70/16 tires on and all of the extra weight from skids, subwooder, and whatever else I normally have in the Jeep, it struggles to maintain the speed limit. If you use cruise control it constantly unlocks the torque converter and/or downshifts. It had gotten to where I dreaded driving it. My 94 with the 4.0 has more low end torque and just cruises on the interstate, so I put a cover on the KJ and let it sit for most of the year. Recently decided to drive it again and Im finally fed up, shes getting 4.10 gears and a detroit truetrac!
Ordered the gears and master install kits from Just Differentials. Nitro rear gears, dana front gears, and USA Koyo bearings. They told me they only had 2 sets of dana gears in stock when I ordered these but it also appears you can order yukon gears on amazon. The truetrac came from drivetrain american since JD didnt have them in stock and I found it cheaper than what they had it listed for anyway.
I ordered the tool for setting carrier bearing preload in the 8.25 from amazon for $25, it wasnt worth making a tool for $25 shipped. Also ordered a timken inner pinon bearing (couldnt find the koyo bearing by itself? We'll see if the timken works) to make a setup bearing, it appears the two diff's take the same inner bearing. Ive read you must use the same brand, I'll see if the timken sits in the race the same depth as the koyo. Im assuming the Jeep has timken in it and when I ordered the master kits, I didnt realize you needed the same brand to make a setup bearing nor did I know I wouldnt be able to find a single koyo pinon bearing. If I had I wouldve bought master kits that used timken bearings.
I've been doing ALOT of reading and watching lots of videos. Gear work is something people always say to leave to the pro's but Ive yet to meet a pro, so its up to me I suppose. I've read several different methods. One method involves a pinion bearing depth gauge. They are rather $$ but Im ok spending money to do things perfect. After getting the dana30a gears I realized that wont work as the head of the pinon bearing isnt flat nor does it have the pinion depth measurement on it. I could measure the stock pinion depth since its also dana, but again, the head isnt flat so I have some more research to do on that. The nitro gears for the 8.25 do have the measurement written on them and the pinion head is flat, but Im not spending almost $500 if the tool only works on the 8.25. So Im just going to make a setup bearing and do it the hard way. Put the original shim in there, set it all up, adjust the backlash, and repeat after checking the pattern. The FSM has very good photos that tell you what to do depending on how the pattern looks. I wish the dana30a had the same side adjusters like the 8.25...
Still have some parts coming on monday but I figured I would get started on it today. Kinda thought I had a ujoint going bad as it had some vibrations when I could get it to go over 70mph (going downhill of course)... The ujoint on the axle end was very tight, but the cups still had grease in them. Originally it had a spicer 1310 in it, so I ordered a spicer. I was able to get one side to move with a hammer and socket, but the other half needed the press.
If anyone from the old days is still around and remembers, I always had a cat working on my Jeep with me. He died many years ago, but this cat showed up awhile back and oddly looks like my old cat and likes to hang out in the garage as long as Im not making loud noises. She said the diff oil stunk
Here you can see the numbers written on the 8.25 gear. When I ordered the gears from JD, the guy said the gears would be marked with a -0.000 number or a +0.000 number. He said thats how much you either add or subtract from the original pinion shim thickness. I'm wondering if the 0.006 is the number he was talking about, but I dont believe I can change the shim thickness by 0.006"... If I were using the pinon depth gauge, 2.373 would be the measurement I would use to figure out what thickness of shim to use. Thats the distance from the center of the ring gear to the face of the pinion gear, this is also the measurement that is not on the dana30a gear. It has neither measurement but it does have a Q0 and H3 on the head, idk what that means just yet.
More to come later...
