John P.
Hello, everyone. I am looking for input from long time members. I need to replace my timing chain tensioners on my 2011 KK @ 127k. Question #1 How much time does it take you to do this job? Question #2 Who makes a durable tensioner? Question #3 Should I just do the entire set using Cloyes parts or can I get away with just replacing the tensioners? (Driver side upper tensioner is the one giving me problems/broken) I ask because I don't have much experience on American products, especially Chrysler. I worked mostly on Nissan junk and tensioners have always been a problem but you can change just the bad tensioner and be just fine. I am planning to do the same here unless input dictates otherwise. If it was a VVT engine I would certainly change the chains but it's not so I'm looking forward to your opinions/advice. Thank you
