Tire pressure: What's everyone running?
Myke
USA
Just take chalk and made a line across the tire. Drive straight for 200 feet and if it wears in the middle only take out 2psi and repeat until it's about almost to the edge. If it all wears away add air. Always better to start over filled (ex. If usually 33psi start at 40psi) so you don't have to worry about adding air just letting air out.
YouTube it for an example.
I plan on doing that once the roads clear up and the driveway isn't a sheet of snow/ice...not complaining about that though. :D
turblediesel
memberable
Alaska
I take it these psi that are mentioned are all cold filled pressures?
Cold is the truth. Heat varies.
34 PSI, more when towing. BF Goodrich all terrain KO LT ???/??X16. Understeers a bit when pushed on hardpack. Haven't driven it in awhile.
Anyone have experience with glass impregnated tires on a Liberty?
