People run 245/65 R17" s and swear by them on same 03 KJ LTD with 17" wheels. I haven't had the gut to try that.
As for wider tires, it is a bit of a problem, especially in the front. They will rub inside at full turn.....
That would be approximately 29.5"x9.5" so I could see that working. I think you'd still have to trim some plastic and pound over the pinch weld, though. But, if your wife's not willing to get a lift, I doubt she's gonna let you cut and pound on it.
You have 235/65R17's, right? I know you can go wider, for sure but, probably not much taller without rubbing on the pinch weld behind the front tires, at the least. I'm not gonna swear to it but, I'd think about the largest you might get would be 30x9.5", and even that might be too big. All these Libby's seem to have different clearances/heights at stock so pretty much, find a local shop that stocks a bunch of sizes and see if they'll let you test fit tires to see what you can get. If nothing larger will fit, go for better tread. The stock Goodyears suck so any improvement will be extremely noticeable.
OK, then that makes it a lot more simple....
P245/70R16.
Done.
Oh. 16s, on a Ltd? Hmm, I thought the Ltd's all had 17's from 04-up. Afraid I can't really help much, except to say that, I wouldn't go more than 29.5" to 30"x9.5" at the most, without a lift. mm x .03937 = in so 235/70R16 = about 9.25"x29"
Doh. yup! I took too long to reply.
Any rubbing gonna happen?
After purchasing my 04 new I replaced the stock 235/70/16's with 245/70/16 BridgeStone Revo's. I had no rubbing issues at all. Let us know what you plan to go with regarding brand.
