Tire size; to regear or not to
LibertyFever
New Brunswick, Canada
In my opinion unless you plan to run much larger wheels like 33" I wouldn't regear your axles.
Regearing the axles is usually a simple job however the Liberty's front axle is IFS.
You will have to drop it to change the gears.
I'm running a 2.5" spacer lift with LT245/75R16 AT tires with my stock gears.
Because I have an automatic transmission I've had the engine computer programmed for the bigger tires so the transmission will shift properly.
Sent from my iPad using Tapatalk
Front is no big deal to swap,2 hours total at most
Programming the computer is only 50 % of the job, regearing does the rest
Even with 30-31 I have found GREAT benefits to a regear, more power, better mileage , doesn't shift as much since +has more power
33s ? then you're looking at at least 4.56s and steel front diff and 6 inches of lift so yes that goes with out even discussing .
LibertyFever
Thanks for your input Tom.
I must confess that you know far more than I do about Liberty's.
I have done more mods to my 95 YJ than to my Liberty.
It runs on 33" or 35" tires and yes regearing the axles was definitely worth the labour & cost.
Would you agree Tom that once you increase the tire size you put more strain on the axles and u-joints?
u2slow
BC
Get above 5000' elevation and you will change your tune pretty quick.
At that elevation I'm doing 70mph usually.... downshifting is easy. You and I debate axle ratio often. Really depends on how you use your ride. 3.55 or 3.73 is way snappier than 2.79 in an 80's Dodge half-ton. I also have a cummins Dodge for towing/hauling chores.
Maybe for you. My DIY'er time on my back in the driveway was a half day to take it out; a couple days to change bearings, seals, intermediate shaft; and a half day to re-install. It was spread out some... the Jeep had be be driven in between.
Would you agree that once you increase the tire size you put more strain on the axles and u-joints?
Based on parts I've used up completely while running bigger tires on the KJ...
- front wheel bearings
- rear ujoint (pinion end)
Between 6500' and 8000' before the SFA swap with 265/75R16's and 4.10's doing 80mph was nothing with zero downshifting and over 20mpg's.
Same size tires,1000lbs less weight,and 3.73 gears at sea level to 500' it would shift all the time and got maybe 14mpg's at 65mph.
The day I installed the 265-75-16s I took off on a 300 mile trip
Half way there was ready to turn around and buy a smaller set ( even though I had the rear gears and another front 4.10 diff waiting to go in )
BUT I hated to even drive it all it did was shift back and forth, best I got was about 15 mpg. Finally resigned to the fact that needed to run with OD off
Week later gears installed HUGE SMILE!!!!!!!!!!!!!!!!!!
back to 21 or so on the road and no more shifting all the time
libordemise
CA
Oh... I'm supposed to get the computer reprogrammed? I have 4:10s and 31s but didn't get anything done too the computer.. Oops
Sent from my LG-K210 using Tapatalk
Earlier models you could do a pinion reset on them for the larger tires
u2slow
BC
I'm starting to understand now... the auto's coarse ratio steppings don't maintain the powerband well when you deplete the effective axle ratio.
Top gears on the 45RFE are 1.50, 1.00, 0.75... and the NSG370 are 1.25, 1.00, 0.84
jeeplib05
Ohio
No option for that for 05s? Even if I did the programming until getting the 4.10s it'd be a hell of a lot better than it is now
jeeplib05
Ohio
Maybe I'll give it a check and take a trip to the dealer next time I think about it..
