Tow package question - got a new Libby :)
JustSumDad
Vancouver Island B.C. Canada
Hi all, so yesterday my daughter got her first car into the driveway... well second as her first she missed the rusted frame and we had to sell it for parts....
FIRST JEEP THO!!!
Anyhow, I have been doing reserch and trying to work out what she has and what can and should be done...
So via VIN I got the build sheet, it says it has the tow group and the HD cooling package...
but there is no mechanical fan on it only elec, now I suppose someone may have taken it off trying to get better MPG but the shroud does not look large to handle the extra fan for the HD cooling as I expected...
so I am confused a bit, and thought I should turn to the forum and ask...
Perhaps in 2003 it was differently setup?
putting build sheet here and a pic of the engine compartment.
any guru's out there can offer some insight?
Equipment Listing by VIN
Vehicle Description - 2003 JEEP LIBERTY LTD EDITION 4X4 SPORT UTILITY 4-DR
CONVENIENCE GROUP I
POWER CONVENIENCE GROUP
MONOTONE PAINT
136 AMP ALTERNATOR
600 AMP MAINTENANCE FREE BATTERY
4-WHEEL DISC BRAKES
PREMIUM DOOR TRIM PANEL
2ND ROW BUCKETS, POWER FOLD/TUMBLE
CHILD SEAT ANCHOR SYSTEM-LATCH READY
NEXT GEN MULTISTAGE FRONT AIR BAGS**
CARGO COMPARTMENT CARPET
CARGO TIE DOWN LOOPS
PLASTIC SWING GATE TRIM PANEL
FRONT & REAR FLOOR MATS
SPARE TIRE COVER
CARGO COMPARTMENT COVER
PASSENGER ASSIST HANDLES
DRIVER ASSIST HANDLE
FULL LENGTH FLOOR CONSOLE
ALL 4-SPEED AUTOMATIC TRANSMISSIONS
DANA 30/186MM FRONT AXLE
3.73 REAR AXLE RATIO
CORPORATE 8.25 REAR AXLE
STANDARD EQUIPMENT
TINTED WINDSHIELD GLASS
FRONT DOOR TINTED GLASS
FLIPPER SWING GATE GLASS
REAR WINDOW DEFROSTER
REAR VIEW DAY/NIGHT MIRROR
SENTRY KEY THEFT DETERRENT SYSTEM
AIR CONDITIONING
ROUTE D2 - CP, MONTREAL
INSTRUMENT CLUSTER W/TACH
240 KPH PRIMARY SPEEDOMETER
VAR INTERMITTENT WINDSHIELD WIPERS
REAR WINDOW WIPER/WASHER
DUAL NOTE ELECTRIC HORNS
12V AUXILIARY POWER OUTLET
PWR WINDOWS, FRONT 1-TOUCH DOWN
LT. KHAKI MET. C/C - MOLDING
LT. KHAKI MET. C/C - FENDER FLARES
HEADLAMP OFF TIME DELAY
HALOGEN HEADLAMPS
DAYTIME RUNNING HEADLAMPS, HIGH BEAM
FRONT FOG LAMPS
CHMSL LAMP
FRONT LICENSE PLATE BRACKET
BODY COLOR GRILLE
BODY COLOR FASCIAS
LIMITED EDITION BADGE
JEEP BADGE
4X4 BADGE
SIDE ROOF RAILS
LIBERTY BADGE
18.5 GALLON FUEL TANK
POWER STEERING COOLER
ENGINE BLOCK HEATER
SPEED CONTROL
LIGHT KHAKI METALLIC CLEAR COAT
6 SPEAKERS
FIXED LONG MAST ANTENNA
POWER RACK AND PINION STEERING
JEEP IS43 SUSPENSION
TILT STEERING COLUMN
FULL SIZE SPARE TIRE
OUTSIDE TIRE CARRIER
P235/70R16 BSW ALL SEASON TIRES
MATCHING SPARE WHEEL
16X7.0 LUX ALUMINUM WHEELS
GROCERY BAG HOOKS
TETHERED FUEL FILLER CAP
PROTECTIVE COATING AND REMOVER
BUILD TO CANADA MKT. SPECIFICATIONS
CANADA DEALER RETAIL
ZONE 22-CANADA-QUEBEC
FOUR WHEEL DRIVE (4WD)/(4X4)
LEFT HAND DRIVE (LHD)
KJ-VEHICLE FAMILY
VEHICLE ORDER TRACKING
CANADA SPECIFICATIONS LABEL
QUEBEC PROVINCE CODE
CLOTH LOW-BACK BUCKET SEATS
TAUPE
TRAILER TOW GROUP
3.7L ENG (EKG)/4SPD A/T 42RLE (DG6)
FLOOR CARPET
CARGO TRIM PANEL W/STORAGE NET
4-SPD. AUTOMATIC 42RLE TRANSMISSION
LOCK-UP TORQUE CONVERTER
SELEC-TRAC FULL TIME 4WD SYSTEM
3.7L V6 ENGINE
DEEP TINT SUNSCREEN GLASS
SUN VISORS W/ILLUM VANITY MIRRORS
POWER MIRRORS, FOLD-AWAY
ALL VEHICLES W/POWER MIRRORS
REMOTE KEYLESS ENTRY
AUXILIARY 12-VOLT REAR POWER OUTLET
SPEED SENSITIVE POWER LOCKS
POWER 6-WAY DRIVER SEAT
ILLUMINATED ENTRY
COURTESY LAMPS
MAP/DOME READING LAMPS
CARGO COMPARTMENT LAMP
3.7L BADGE
50 STATE EMISSIONS
EURO STAGE 6 EMISSIONS W/EOBD
HEAVY DUTY ENGINE COOLING
OPTIONAL EQUIPMENT
4 12/31/24
ALL RADIO EQUIPPED VEHICLES
AM/FM CASS/CD RADIO W/CHANGER CTRL
LEATHER WRAPPED STEERING WHEEL
GOODYEAR BRAND TIRES
ALL ALUMINUM WHEELS
CLASS III RECEIVER HITCH
7 PIN WIRING HARNESS
7 TO 4 PIN WIRING ADAPTOR
FRENCH/CANADIAN LANGUAGE
WITHOUT BILLABLE FUEL
SPRING - LEFT FRONT
SPRING - LEFT REAR
SPRING - RIGHT FRONT
SPRING - RIGHT REAR
GVW RATING - 5600#
FAM: CS TRACKING: 60906M05 MY:2007
FAM: KJ TRACKING: 21101J14 MY:2003
FAM: AB TRACK PLAN: S.E.C. #1
CUSTOMER PREFERRED PACKAGE 2TF
CUSTOMER PREFERRED PACKAGE 28F
FEDERAL A/C EXCISE TAX
You are correct, that is certainly not the HD cooling. From looking at that fan, thats not even the factory electric fan and it appears to be wired with crimp connectors.
Im not certain, but I 'think' the HD cooling package came with a single speed electric fan. The non-HD cooling came with a two speed electric fan. It appears you only have two wires there, so that may be a single speed fan. That would line up with it, at some point, having the HD cooling package.
I'd be careful with that aftermarket fan. Who knows if its capable of keeping it cool and there is one thing you should know, the 3.7 should not be overheated.
JustSumDad
yes I looked and it only has two wires, single speed fan, I read somewhere that the two speed fan came out after a few years, this being a 2003 I thought that would be normal.
This electric fan sure fits in there perfectly, looks engineered for the install, not a universal I don't think...
I know for sure it had HD cooling from factory due to build sheet...
we have had it out on hwy and out off road now for over an hour each time and it held temp nicely but weather being cooler these days that may not be a good indicator...
do you know if the shroud and dual fan setup from a CRD would transplant?
I think all CRD had dual fan and there are a few being parted out...
not having good luck finding a 3.7 with HD parts...
Any reason why you want the HD cooling package? If your daughter isn't working it hard the standard setup will be fine, most were not sold with the HD setup, my CRD only has the engine driven fan, no electric fan.
JustSumDad
First it appears that this is an aftermarket likely Dorman cooling fan, I suspect its ok for basic daily driver stuff but as soon as its working hard I have trouble trusting it.
Second, one of the reasons for selecting a Libby was that it could tow a bit and another is that its small and can get in and out of stuff much eaiser than a bigger rig, also self recovery is way eaiser with a small 4x4. Also she works in the conservation field, saveing eagles, tracking wolf packs and stuff like that, so the next step in the goal list is to get a small tow behind house she can live in. In theory without the HD cooling I understand the Libby can tow 3500lb but with the HD cooling its 5000lb
Hard to find anything one could reasonabley live in for half a year boondocking under 3500lb - in her university student price range anyhow...
she would not have to tow alot, but likely twice a year to get to and from her summer possition, and each of those times will be in mountains and possibly half way across Canada...
WheelNut
Vancouver, BC
I'd imagine all the wiring for the HD cooling setup is present there. You could just buy a new clutch fan, a new electronic fan and a get a shroud from the junkyard. Can't be terribly expensive (check Rock Auto), and those are parts that will give the Jeep a reliability boost since they are new rather than 20 years old, so good preventative maintenance in a way.
JustSumDad
ya thats where I am going at it now, not much where I am on Vancouver island tho and shipping on something the size of a shroud is gonna make it pricy I bet. I will take my time and keep my eyes open... Time will tell... RN I am going to fit a decent temp guage with an alarm to protect from overheating it.
derekj
Powell River, BC
Looks like Rock Auto has the electric fan, clutch, and fan blade - only about $400 cdn shipped.
JustSumDad
I found an outlet in Sherwood Park AB that seems to specialize in tearing down Libby's he says he has all the parts for $200 but does not include shipping...
Still hunting :)
Main issue is the shroud, without that shroud the clutch fan wont do half its job....
derekj
Powell River, BC
Still hunting :)
oh - what is the business called? I'm always on the lookout for bits and bobs :)
JustSumDad
found on kijiji
65Corvair
Iowa
The towing packages also came with a power steering cooler on the driver's side of the cooling package. You should be able to see it in the grille pretty easily.
