:icon_idea: I installed a PML 1.5 quart over stock Trans Pan for the 42RLE do your have the 42RLE or 45RFE? Never had a temp light since.arty52:
Anyways if you have the 42RLE the new aluminum pan will keep things cooler and the extra 1.5 quart of ATF+4 helps!
A drain plug is standard and allows easy drain & refill when u need to. You can also install a trans temp sensor in new pan. Fits above OEM skid plate perfectly.
YourCovers.com 42RLE Transmission Pan
I used a Lubelocker gasket and has been absolutely leak free. Unlike the te OEM pan which was constantly weeping and the main reason (beides heat) I went to the PML.
50122[/ATTACH]"]You must be registered for see images attach
Sorry to hijack OP's thread but I'm trying to justify the cost of upgrading to this pan.
Is it mainly the pan being AL, larger, and having a drain plug the key features?
Also lubelocker doesn't seem to have a gasket for the 45RFE?? other options?
