transfer case noise
XWrench3
Today was the first "real" snow day here, meaning that the snow actually accumulated on the roads enough to make them a slippery mess. i turned on to one of our two lane highways (55 MPH) speed limit, and by the time i got up to 35mph, i had gone sideways 6 times. so i slipped the transfer case up to 4 HI. well that was not at all what i had anticipated. it went in fine, like a vehicle with 167,000+ miles on it should. but when i tried to accelerate slowly, there was an utterly awful groaning / howling noise from what i have to assume is the transfer case, since engaging the case was the only difference. i let off the throttle, and the noise dissipated. slowly accelerating again, the noise came back after about 38 mph. so, keep in mind that i have only owned this vehicle for roughly 2 months. and this is about the 5th or 6th time i engaged the 4wd. the first time was on a sand road at about 10-15 mph. it made no noise, but it did feel to me like it was binding. about 10-12 days ago, i changed all the fluids underneath the vehicle. front and rear axle oil, engine oil and filter, automatic transmission fluid and filter, and transfer case fluid (atf+4 going into the transfer case and automatic transmission). so when i came here to post this, i ran across this,
https://www.jeepkj.com/threads/transfer-case-fluid.75746/
when i turned onto the road I live on (which is notoriously slippery when it has snow on it), i pulled it back into 4wd high range at a much lower speed, and it sounded normal (quiet) until i reached that same 38 mph. i slowed back down, and it was fine again. i never did go any faster than about 42 or 43 mph, as the noise was so bad. so i did not want to chance exploding the case all over the road. so i did have one thought / question, which is does the transfer case have clutches in it that require that additive that you use in Posi traction axles? one thing that i did not expect is that this SUV handles simply terrible in snow in 2wd. so it appears that i am going to need 4wd when the roads have limited traction available. any ideas what could be going on???
KJs DO NOT handle terrible in snow, IMO and many others
tires are a lot of the issues when people say they handle badly
I've driven both the 03 and 04 in 8-10 inches of snow on the roads and they went fine in 2 wheel drive
That is running Duratracs on the 04 and Wildpeaks on the 03
Now I forget but have you ever checked the rear CV on the front drive shaft OR the right side CV and Intermediate Shaft The rear CV on the front driveshaft is usually good till about 75-80,000 miles before the rubber boot starts to let go. One KJ get together there were 25 KJs and 19 the rear boot was gone or getting bad
and no the transfer case does not require additional additives
what type of tires are you running and how much tread left on them?
Avon Lake, Ohio
Id agree with Tomm and check your front driveshaft.
Like he said the Transfer case side of the shaft goes bad real fast and the bearings create this hellish noise. But you can rebuild it yourself for around $30.
Super easy and about a 20 minute install with snap ring pliers and a flathead.
XWrench3
the tires are some off brand (PROVIDER HT) tires, and i knew they were street tires. that being said, they have good sipping, and have 9/32" on 2 of them, and 8/32 on the other 2.
no, i really have not looked at them. that would have been good to know before the snow hit us. as now i will have to wait for it to dry up in order to check them. its a melting, slush mess right now, and i do not have a place to get out of the weather. so i have to work in the driveway.
Well half worn out street tires from a cheaper company, rubber compound not being the best, they will handle snow badly
As far as the rear CV on driveshaft and RF CV and Intermediate shaft, common issue on these KJs
Doing10to20
Kjs do good in the snow. Only time I've had issues is pushing it in the mountains with alot of snow. Gotta be your tires messing you up.. on the noise everything they said you gotta check
RF*
XWrench3
ok, I got a chance to crawl under it, and sure enough, the boot is torn. so I assume that means that the joint is dry, which is why it sounds like the devil being tortured to death? the right front shaft boots are fine. but R&R the driveshaft looks like a lot more than a 30 minute job.
XWrench3
oh, one more question, can I drive this with the drive shaft removed? its the only vehicle I have at this point that runs and is safe to drive.
XWrench3
Like he said the Transfer case side of the shaft goes bad real fast and the bearings create this hellish noise. But you can rebuild it yourself for around $30.[/QUOTE
Where did you get a rebuild kit for $30.00ish? the auto parts stores around here are in the $160.00-180.. range!!!!
Avon Lake, Ohio
XWrench3
thanks, I did, and they do a nice job of packaging everything.
so now i have to decide whether i want to use the new allen bolts that came with them, or the factory regular hex bolts. if it was going to be a pavement queen, i would just use the allen head bolts, but its not, and i know what happens to allen head bolts in the dirt. they get packed with mud, and you have to spend half an hour digging the crap out of them before you can loosen them. if there is a reason i NEED to use them, let me know, otherwise these are going to go in the spare parts bin, and used at a later date on a different project.
XWrench3
Something just popped into my head. I'm not going to know if this fixes my problem until we get another snowstorm again, am I?
I always use the old bolts, I have a ton of those allen bolts they send along in the bin, gotta find something someday to use some of them up
XWrench3
well, one job done. now i have to find a squeak that is driving me NUTS! well, nuttier than normal anyway! lol
Royy
Western CO
Use the old hex bolts. I had issues with the inside of several of the allen head bolts getting ground down, so the allen wrench/bit wasn't able to properly grip the bolt anymore. The material of a lot of those cheap aftermarket bolts is just way too soft.
XWrench3
I did, mostly because of the mud issues though. i did not even think about the strength of the bolts. but thanks, because that is good information to know, since i will use the bolts in some application. now i will know not to use them in a high stress application.
