whitejeep05
Hey guys,
Hoping someone here has seen something similar and I can find an affordable solution to this problem. My 05 Liberty jumps out of gear in 1st whenever the gear isn't firmly put into place. It drives fine if I shift carefully into 1st, or hold the shifter in place, but it jumps out of gear if i'm not careful with it.
Has anyone else had this problem, and what was the fix? I know the obvious answer is a transmission rebuild(synchros?), but it drives fine if I very deliberately engage the gear. I'm hoping it's like a shifter alignment problem or something along those lines...
Thanks in advance!
Thanks in advance!
