Glad you found a solution. BTW-if the linkage breaks and strands you, there is a workaround to get you home. You can set the parking brake and put t-case in neutral (or have someone inside the Jeep holding the brakes, put blocks on wheels, push it against a tree, etc.) with it running and climb under and move the lever on the trans by hand to put it in gear. Of course, if you're by yourself and not completely confident in your parking brake or ability to do it safely, call for a tow. If you're in the woods or BFE, use your best judgement, knowing an ambulance won't be quick if you ***** upOK guys, here is were it's at.
the trans place verified the ****** is in need of a rebuild.
I did consider a junk yard replacement however, I am going to use her
for towing long distance, so I think it is in my best interest to have it rebuilt properly.
So many options on the front drive shaft.....
Thanks for that link.
I could rebuild the front and back for about $140 dollars.
I called the auto recycle yard ( The Mens Mall ) and found a slightly
used front drive shaft for about $100, (115000 miles).
The guy across the street said to wait a day and he would look it up.
He come back and said he can get that drive shaft after market
for $132.
going with the aftermarket drive shaft for the same reasons as rebuilding
the ******.
Going this route on the front drive shaft is saving about $600.
She should be on the road in about a week and a half or there abouts.
thanks to you all for your comments and suggestions.
BTW guys. My Jeep Liberty has about 138000 miles. I had to replace
the shift cable, from the shifter to the ****** because the part that
connects to the transmission wore the plastic end enough to be loose
and it fell off the trans handle (shifter).
It just fell off, no warning, and of course, when that is off, you can't move.
So if you have alot of miles on your Liberty, you might want to check it out.
thanks again, much appreciated.
