I am replacing the tri-link because its worn out. but I am having a terrible time getting the bolts to break loose. I have been spraying the bolts for 4 days now, and they still will not budge. I talked to a local repair shop and they said they have a lot of trouble also. and many times the bolts break off. I don't want that to happen, because I know what a chore that ends up making. I have tried hitting the bolts trying to shock them hoping it might help them break free. something that just popped into my head is I am assuming that these bolts thread into the chassis itself right? meaning that these do not have nuts, where if I broke the bolts, it really would not matter because I could just replace the bolts and nuts without issues. they are so close to the fuel tank I am concerned about using a torch on them. does anyone have a trick that would help me out? if I can get them moving, they will usually come out. //// also, if I can not get the ball joint nut to come loose, will the tri-link come out if i just break the ball joint nut off? I have never come across one of these before, so I really do not know what I am getting into.
