- Joined
- Dec 17, 2006
- Messages
- 10,612
- Reaction score
- 41
I have run my 265/75R16 Trxus Mt's for 12,000 miles now and have been a really good tire.Paid $114 apiece from 4WheelParts.
Stats.......
265/75R16
D load range
8 ply rating,2 sidewall,6 tread
Mounted on 16x7 rims(recommended and stated on sidewall)
19/32" tread depth
pro's......
Very good traction on all surfaces,wet or dry
70% tread left after 12,000 miles even having very soft rubber
hard to beat in the mud
Sipped for better traction on ice
Great sidewall flex when aired down on the rocks
Very tough sidewalls even though only 2 plys
con's.......
Wear very bad if a perfect aligment is not kept
Need to rotate every oil change
Don't like tire pressures below 10psi on non-beadlock rims
Can be very hard sometimes to balance(2 of mine balanced with little weight,the other 2 took over 14oz to balance)
Stats.......
265/75R16
D load range
19/32" tread depth
pro's......
con's.......
