melted said:So the dumb question: For years, coolant systems have had temperature sensor controlled electric fans that run long after the key is removed. Is this not a better answer than a timer that keeps the engine running?
No. The fans cool the radiator and the coolant fluids but do nothing to circulate the fulid through the engine as it cools. Thats not an issue for non turboed vehicles. For turbos though they are cooled via flow of liquid through the housing, because they spin at such high speeds (100,000rpms in nothing) the heat they generate is very high (my GTI runs ~1000-1100 and higher when under boost). The liquid used to cool the turbo is also as such much hotter as a result. If you shut off the car before giving it a good cool down the hot coolant can cool to rapidly and cake in the feed lines which will reduce the ability to properly cool the turbo as times goes on and can lead to turbo failure from heat. A turbo timer keeps the car running, which keeps the fluids flowing and as it sits without load it cools everything as needed, something simply running a fan cant do.
