Water pump
Froggercn
Cincinnati
HELP ! Today, power steering , heater went out and battery light came on and started smoking from under the hood . Firestone says water pump went out $446.00 . They said they have to replace belt also ( too wet) to put back on and $100. Of that is to flush and refill reservoir .
Please can anybody tell me if this sounds right ?
Thx��
2002 Jeep liberty Limited
1BADKJ
Barnegat NJ
Pump, labor, coolant, and coolant flush. Sounds right. You dont need a coolant flush though. They are draining 80% of your coolant when they change the pump.
Not a bad idea since it's a '02 and most likely never has been done before and hence way over due.
Anyways changing the waterpump will only leak out maybe 30%-40% of the coolant anyways and the flush uses a chemical to clean other parts of the system so never a bad idea.
Mjewell
Upstate ny
Just did my water pump on my 2003, very simple, mine didn't have the clutch fan which made it easier. Actually took me longer to remove the stubborn hose clamps than replace the pump
Jbergun
Chicago
I did my coolant system last summer with the hd cooling wasnt easy but it wasnt hard. I did the water pump radiator hoses belt for alot less than most pay.
JasonJ
Michigan
If you have some mechanical skill, do it yourself. The only real "hard part" is if you have a mechanical fan, and removing the fan clutch.
Otherwise, if you can't do it yourself, you'll pay the man who can whatever he asks for. What are you going to do, not fix the truck? Besides, the price quoted seems pretty spot on to me.
