2003년 기준으로 3.7L입니다.
사진과 마찬가지로 엔진 아래에 오일이 새고 있습니다.
이 문제의 어떤 부분인가요? 일시적인 문제인가요?
Camsaft seal?Check rockerbox gaskets at the top of the engine, they may be leaking and the oil running down the back of the engine, easy job to replace the gaskets.
The other thing that often leaks is the rear main oil seal on the crank, big job to change as you have to take the engine or gearbox out to access it.
That would leak at the front of the engine and spray everywhere off the belt.Camsaft seal?
