What does Trail Rated add to a 2006 Sport?
atikovi
Suburban Washington DC
Besides the emblem of course. Body lift? Tow hooks? Skid plates? etc. Just bought it. Can you tell if it's lifted? I don't see tow hooks and haven't checked for skid plates yet.
You summarised it perfectly with the emblem.... probably something someone's bought and stuck on.
It might be a dealer upgrade, have a look underneath and see what's there, there don't appear to be any tow hooks but it's got the tow receiver that was added to provide protection for the fuel tank.
Stock ride hight is 19" from the wheel centre to the underside of the arch flare, less than that = worn out suspension, more would suggest a lift. It looks fairly stock in the pictures.
Stock tyres are 235/70/16 these look like standard alloys with a set of fairly new tyres.
Low spec trim was cloth, the Limited and some special editions had leather. I'm guessing that's a fairly low end car as it hasn't got spotlights in the grill or body coloured wheel arch moldings.
The common rust spots are inside the plastic trim on the sills / rockers and the lower rear arches. Also check the roof, they go around the 3rd brake light. If it's rust free that's a major point, a lot of them have melted in the salt!
The bodywork on it looks nice and straight + the paint looks good too so I would think it would sell quite easily.
Gyro
Nova Scotia
I think trail rated just means it is 4x4.
Most other things are trim level upgrades,Limited,Renegade,Rocky Mountain Edition ect.
Gyro
klc
“It flies like a truck.”
PNW
The "Trail Rated" badge on a Jeep signifies that the vehicle has passed rigorous off-road tests in five key categories: Traction, Water Fording, Maneuverability, Articulation, and Ground Clearance, demonstrating its enhanced capability for challenging terrains.
u2slow
BC
Cool. So trail-rated means 4x4!
u2slow
BC
A locking axle in a 2wd does pretty good. I did that with my dodge pickup so it doesn't get stuck doing basic chores.
nmbluept
Rio Rancho, NM
Your 2006 Sport looks exactly like my 2006 Sport - nice choice :) Yours looks to be in great condition. The Sport was the basic trim level in the day, not much extra.V-6, AT, power windows/locks, AC, key fob locking, with basic cloth seating surfaces. No cruise or anything like that. All in all a very functional vehicle. The "Trail Rated" thing is a sales gimmick Jeep still uses on many of their vehicles. I bought mine to tow behind my motor home, Liberty's are the perfect toad - transfer case in neutral, AT in park, key to unlock position and off you go. Once to your destination you have a vehicle that can comfortably carry 4 adults, go on the beach, some off-road trails and it does well in snow. Mine has been towed 1000's of miles; to Alaska and back, multiple trips to both coasts and many places in between. The Libby has been ultra reliable, just basic maintenance. Things like tires, batteries, brakes, O2 sensors, change oil/filter differential fluids on a regular basis and it keeps going.
It looks like I have the same wheels as you have, not the stock steel wheels in the picture. Hope your Liberty serves you as well as mine has,
u2slow
BC
'Sport' is the label when it's not a Limited or Renegade. It's not an upgrade; it's the default. Options (like V6, auto trans, etc.) were available on the Sport.
JustSumDad
Vancouver Island B.C. Canada
I have seen plenty with no badge at all, no Sport, Limited or anything, just a Libby 4x4 with v6 auto. The limited/sport/renegade simply meant it had some base addons that changed what core features were on it. So, if you were at the dealer and ordering your Libby from the factory... and you started with a Limited trim level, you already had power locks/windows etc but if you started with a 'no badge' or base model, you had to add those things.
Think of it as just a starting trim level, not a factor in what you had when the order sheet was completed. You could order a base model and add every option/feature a Renegade had for instance... except you would not have the Renegade badge when it was delivered...
So, in the end, what does 'Trail Rated' add?
Not much :) it depends again on what 'trim level' was the starting point...
I suspect in the OP's case we may find that a limited slip axel was the only defining point that 'earned' this badge...
I suggest that the badge means nothing, the trim level means nothing...
IMO take the VIN and generate the as built sheet, that tells you everything.
