Black03Limited
Hey everyone, i had recently had problems with my rear speed sensor/wires, had the shop "fix" it (they couldn't find the problem, but it cleared itself up for about a month or so).
Anyway, i started noticing the ABS pulsate when it shouldn't have been, off and on. Then the ABS light and brake light came on and off occasionally. Then finally, they came on and stayed on with the CEL. Code 0500. What a surprise. Speed sensor is brand new, fluid in differential is brand new, tone ring and wires were checked by the mechanic and found to be in good shape (so they said). So i got underneath and popped the speed sensor off the differential again and i noticed a HUGE build up of grey/silver metal flakes. I am more than sure this is causing the sensor to stay on or be fooled, whatever it does.
I took a picture of the sensor so you could see how bad it is. Sorry the picture is hard to see, but there is a big pointy chunk hanging off of the end of the sensor as well as other spots on the sensor.
What is wrong in my differential? Why are so many metal flakes coming off so quickly?? Its only been just over 1000 miles since the dealer checked the tone ring and changed the fluid in the rear diff. Im kind of concerned.
