What Size Roof Rack/Basket?
Fired
So how do you carry a plus size spare?
Same way as your thin girlfriend, I suppose. :boobs:
Oh - you meant TIRES!!!! :happy175:
By the way, my scholarship dough is scheduled for about two weeks from now. The roof rack may not be the first thing I do, but it is pretty high on the list.
kj04libby
Tuscumbia, AL
Mine was $89.89 shipped from Amazon its 50x38x5 includes the crossbars and it holds my weight (at 250lbs I'd consider that strong lol) the only problem is it didn't come with instructions but everyone that bought one said they didn't get instructions either but trust me its not hard to put together especially if you watch the video
EDIT: Here's a video of that very same rack I bought on a 2004 Jeep Liberty on YouTube
http://www.youtube.com/watch?v=pwYw1KcqFnw&feature=youtube_gdata_player
depends on which way you have your bracket turned
also even if it does hit for some reason, just make brackets to move it up an inch and out an inch / problem solved
John3seventeen
WV Panhandle
That's only about an inch wider than a 245/75/16 so a half inch closer to the tailgate depending on the backspacing of the wheel. I can still get my arm behind the 245 with factory wheel.
LibertyFever
New Brunswick, Canada
FYI: here's some Pros & Cons
Pros: you'll have more storage space for carrying stuff, you can mount extra lights and it looks cool
Cons: your gas mileage will suffer and depending on your choice of trails overhead branches will catch on the rack
Maybe you can find a roof rack with a faring to deflect air & branches.
yellocoyote
NW Chicagoland
I don't run a wind fairing on my basket. I didn't lose mileage because of it. I did increase a little in wind noise, but it's nothing the tires or the radio doesn't fix. :D
Yes, the branches hang up off-road sometimes... but the jeep and the basket is stronger than the tree, so I've always won that battle. ;)
4x4kayak2112
tx
Do you have a link to the amazon listing?
Sent from my Home Phone using Tapatalk
4x4kayak2112
tx
Sweet! I like the idea of the lights! You have any pics of it installed
kj04libby
Tuscumbia, AL
Nope, I bought it and before it got here I stacked a rod bearing. I'm going tomorrow to buy a long list of parts from Autozone to start rebuilding the bottom end of my engine. As soon as I get it back on the road I'll get y'all some pics!
Paul M
Virginia Dale, Colorado
We like our Rola on homemade 3/4 gas pipe cross rails bolted to the stock rails (which will hold 150#'s). Not very far off the roof, looks good, not much wind noise, a slight decrease in mileage per tank on the highway but a non-issue. Somewhere on here I have a write-up how I made the cross rails.
Fired
I've got this over in my Member Journal, (http://www.jeepkj.com/forum/f222/profdlps-2007-liberty-project-54355/) but thought I'd ask here since I hope to order in the next day or so.
OK, dumb question #362:
Concerning this rack:
Amazon.com: 62.5" Roof Luggage Cargo Storage Rack with Fairing: Rage Powersports: Automotive
It measures 62.5 x 45 x 6.2 inches. I measured the rails and the separation between them is 41" at the front and 39" at the rear (I.D.) Being as this rack is 45" wide, is there any reason I couldn't U-Bolt the rack directly to the rails and forego the crossbars altogether?
This one seems to have a finer wire grid at the base so I might look for one with a sturdier bottom on it.
Would this work?
Would this work?
Yes and no
Depending on the construction, how you are going to use it etc
But its a lot better idea than having then 10 inches above the roof line :emotions33::emotions33:
