Where does this overflow-tube go?
clapperc
Blair County, PA
I found this just dangling down near the engine-block... So I pulled it up. May I assume it first slides into the U-bracket on the bottle? Then where from here?
Jo6pak
Left coast of WI
I just went out to look at mine. But it's different from yours in the pic.
What year is you Libby?
Fired
My Jeep is also a 2007. When it's not dark and not raining I'll try and remember to go out and have a look. :)
On other KJ model years ('02 to '06) that overflow tube runs along the upper radiator hose on the driver's (left) side and connects into a fitting on the radiator next to the upper hose. Not sure if the '07 would have that same fitting or not - I thought all KJ model years used the same radiator.
Is that not true? :emotions133:
You have a changeover year
nothing is the same except everything is,
well except for the things that are different
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
2007 has a lot in common with the KK... this is one. Likely for commonality while also pushing the Nitro down the same line for that year. The cooling system setup is one, CANBus is another.
Fired
It was finally not dark, not raining, not snowing, and I needed a break from the old schoolbooks. Sorry it took me a week for the planets to line up like that. :Big Laugh:
As I mentioned above, I have a 2007 as well with the same two hoses
Yes, that is correct.
The bottom hose attaches to the radiator like Bob mentioned in Post #9.
Yellow Stars:
The top hose acts as an overflow for the overflow. If the expansion tank gets full it basically dumps the excess on the ground under your right front tire instead of having it spew all over the engine compartment.
I'll do Red Stars for this one because it's just so cute! :slap:
This is down by the hump for what is the right front tire wheel well:
Here I'm pulling some of the other stuff out of the way. The hole for the hose is where the red star is and the hose itself is directly below it:
Finally, I've pulled the hose out altogether so you can see the oval cutout it slides into:
Basically, just a small hole in the bottom of the engine compartment for a drain hose. Mine is not clipped to anything or fastened in any way at the lower end.
And I have a really good "That's what she said" which I would love to share but I am far too polite and respectful to do such a thing. :Hump:
