Yellow oil sludge on oil cap
rockymountain
Spencerville, IN
I am having this issue on my 03 liberty. It gets quite a bit of condensation under the cap and it clogs up the PCV valve. I changed the PCV valve yesterday and it ran tip top for an entire day, and then went back to a rough idle. I didn't clean out the filler neck / cap and think some of that sludge got in the new valve already.
Is there a link to a complete kit for re-routing the PCV valve on an 03 liberty sport?
https://cda.extra.chrysler.com/icon/sqwrp/files/2500108.pdf
All the info can be obtained in this document. Just need to follow it closely.
Daveos
Utah
I have bought all the parts I need to reroute it.
Daveos
Utah
The TSB Recommended rerouting it if there are running problems. Mine is clogging up my PCV valve and causing it to freeze up. I live in a cold climate. If it isn't causing the engine to run like crap, I wouldn't worry about it. If you start to notice power loss like you are not getting gas, check the PCV valve first. I just dropped about 300$ on parts before I discovered it was a 4.99$ part.
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
Mopar guy,
We are always abused on forums. Get used to it. I get crap too... and don't get me started when they ask for credibility. To those idiots, I say...
"I only build them."
They usually freeze.
Can we convert back to the old PCV system?
I miss the sludge. :(
67Customs
North Carolina
Same thing for me. It cloggs up my PCV and my mileage has to be suffering some.
Daveos
Utah
I was losing power on warm starts and couldn't figure out what was going on. New fuel filter, new spark plugs, new ATS, new TPS, cleaned throttle body, cleaned evap canister, new battery, seafoam, and new purge solenoid. Whew. I finally put a new PCV valve in and could see the other one was totally clogged with that sludge crap. Was surprised that fixed the problem.
Got to remember to start simple first.
Mopar guy
Minnesota
The freezing issue caused a pressure build up in my engine and a leak from the front crankshaft seal. Since the seal had been replaced 20,000 miles ago, a retired Chrysler tech told me to do the PCV update before having the seal replaced. That was 4000 miles ago and no leakage since
Mopar guy
Minnesota
The new PCV Valve goes into the back of the drivers side cylinder head. There is a hose nipple currently in that location, which the crankcase breather hose uses
67Customs
North Carolina
Found it. Thanks! The kit was about $40. Going to try and change it this weekend. I hope it helps. I'm sure it will.
