Anybody replace their sway bar bushing?
Bennett
Active Member
Green Bay
I think mine needs to be replaced, because I am getting lots of squeaks from the front end... I was looking at a daystar Polyurethane bushing to replace it.. Does anybody have any expierence with this bushing?
Found the bushing over at performancecenter.com for 25 bucks.
Here is what my bushing look like right now... (white stuff is grease) but they look just smushed to one side..
Also I just ordered all new shocks (ranchos RSX's), so I will be taking apart the entire suspension soon.
Thanks,
Bennett
Bennett
Active Member
Green Bay
Oh I forgot to mention I have the rusty's lift 2.5 spring setup on here.
Yea I read somewhere that the daystars can squeak or something... Most likely my stock ones are filthy inside and could use lithium grease.
but as long as I am taking the suspension all apart, I am just wondering if I should just put new ones in, either rubber or poly..
right now I have this creak noise over any bump in the road, kind of annoying.
Bennett
Corwyyn
Southeast of disorder...
Does the creak noise seem to go away once things have limbered up or does it do it all the time? If it disappears then its probably temperature related, if it does it all the time then replacement will probably help. And as you say, since you are going to be taking the suspension apart, why not do it now?
valvestem
Northeast US
Squeaky Joints
pixeldzn said:
I have heard they can squeak really bad, especially in cold temperatures.
Yup, mine squeak more the colder it gets up here, front and rear.
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
December 2004: Sway Bar Bushings squeak. It annoys me, so I get them fixed. New bushings and grease fix the problem.
December 2005: Sway Bar Bushings squeak. It annoys me, but since I obviously can't do anything about it, I just let it go. It's just going to keep coming back.
Well, that's my story. :)
Bennett
Active Member
Green Bay
Well last night I took the tire off and sprayed everything up again... I thought it was coming from the bushing, but I believe it is coming from inside the drivers side front shock. Kinda weird.
kj lad
North east England
I have daystar swaybar bushes up front. They do sqeak a bit, but not as badly as I was told. I re-installed mine with copper slip and the're loads better now.
Ian
