04 KJ won't move, feels like it's in neutral please help!
Liftedkj
Kentucky
Hello we are new here, my husband and I bought a 04 jeep liberty 3.7 v6 a few months ago. Well it had been driving fine and one afternoon we were going down the road when it felt like the transmission popped itself into neutral, it didn't feel like a slipping transmission it felt like you accidently hit the shifter into neutral, well we messed with it a little and after we put it in reverse it drove home. Well the next day it did the same then the next day it would only move feet then it would do it after it warmed up it was just no go. Well now it won't move at all. The only code we can get it p0700 That stays anyway we had a p0502 or similar to that for vehicle speed sensor well we changed both of those still no go. The transmission fluid is full and an Amber pink color and doesn't smell burnt. When the problem first occurred when we would start the jeep it had a "whirrling noise" but that has stopped (It was a little cold when that happened so may not be related?) When in park if you put the gas pedal all the way to the floor it "louping" sound and doesn't go over 4000 rpms but that's only in park. Not in park it will red line of you put the pedal down (we don't do that much just trying to get a feel for the situtaion) we have no clue what is going on. When we had it hooked to a computer after we first bought it the jeep threw a code for a "transmission shift solenoid" but that code isn't there now. Does anyone have any ideas? Thanks alot.
Tog
AU
I repeatedly got the solenoid code till finally I gave in and got the trans rebuilt. Torque converter had failed and dumped rubbish all through the box after rebuild it's flawless
Liftedkj
Kentucky
Okay thanks for the reply! It seems like it just keeps throwing random codes once but the p0700 stays. It is confusing. Should I unhook the TCM and see if it helps? Maybe clean the connects?
The PO700 is a generic trans fault...basically means it's not an engine related issue. Best thing to do is get the CVIs read, but it sounds pretty knackered.
Liftedkj
Kentucky
Thanks for the reply! We reset the codes and now that it won't move the check engine light wont come back on no matter how long we let it idle, could a reader still pick anything up? Like read the old code?
Yeah, the DRB3 will be able to read the CVIs even without a light on. They're active/running values.
Liftedkj
Kentucky
So will my local mechanic have one of those type of scanners? Should I ask for that type when I call my favorite local guy? I just hate to pay him 125$ to come to my house and hook it up and tell me the same code I already know lol.
Looks for a trans shop!
Ya just needs a re-build and the good news is... it remained in the Jeep!
59474[/ATTACH]"]
:gr_grin:
