05 tail light issue
WRB
Ohio
Hi all
I am new.to the group. I just bought my daughter and 05 liberty for her 1st car. The drivers side tail light doesn't work on daytime running but it does when you turn on the headlights. Kind of confused.
Hi all
No other issues with the lights ?
Lucky girl for sure
Plus gotta know what part of the Buckeye ?
teeje
Toledo
I'd like to know too. Try this. Switch the bulb from the passenger side and see if it does the same thing. Then get back to us
Sent from my SM-G935P using Tapatalk
WRB
Ohio
I checked it again and the front marker is out as well but when I turn on the lights they all work.
I am around the north Lewisburg area kind of West Central ohio.
dude1116
Pompton Plains, NJ
It could be your multifunction switch. Have you tried changing that?
WRB
Ohio
Not yet I have only had the jeep for about 3 hours. Lol
I have read some things on bad DRL relays.
WRB
Ohio
The bulbs work when the headlights are turned on. They are only out when the daytime running lights are on
Gyro
Nova Scotia
DRL should only light the head lights.No tail or marker lights.
My 2 Jeeps are this way.I assume the relays are the same n&s of the border.
Had ds low beam blow yesterday,DRL must run off the high beam at reduced voltage?
I had 2 DRL w/lights off and 2 high beams and 1 low beam w/lights on.
Gyro
dude1116
Pompton Plains, NJ
Gyro
I believe OP is referring to parking lights...not DRLs
WRB
Ohio
So I looked at this a little more and realized that with the headlights off only the right marker and tail light are on. So if this jeep has Drl they are definitely not working correctly. I may buy a relay and start with that.
dude1116
Pompton Plains, NJ
DRLs require specific programming of the computer since only export models were like that. So whatever problem you're having has nothing to do with "DRLs"
Are you referring to the fog lights in the grille?
