06 liberty won't start
Yahoo
Battery good replaced ignition switch and actuator. Lights on in dash. Checked starter at relay cranked won't start with key on.starter ok. Any ideas. Ok just started drove it awhile.then . Won't start. Next morning went out fired up ? Thought maybe I had ignition switch not lined up slightly off of actuator?
Manual or auto?
Manual has the clutch interlock switch that can fail.
Might be a dying starter solenoid, time to get the multi meter out and see if the key is putting a supply to the solenoid.
