Good points, the advice is gladly taken.
So do you all think the spacer was used to counter sagged springs, or that it was used to just lift the vehicle with existing springs that later sagged? The main thing I'm asking is if its a overall lift kit then replacing the front struts/springs with new ones minus the spacer may create a ride height difference with the rears, that will then need to be corrected.
IDK what the height difference will be with new replacement springs minus the spacer vs new springs with spacer vs existing setup. I am already slipping down the $$$ rabbit-hole where a rattle has turned into a un-needed UCA replacement, now new strut assembly... and I still dont know if any of this will fix the rattle, which i still believe is due to loose UCA bolts.
Should the existing spacer be used with new springs?
-DallanC
-DallanC
