2012 liberty
Kat54
Hey Jeepers
I have a 2012 liberty minimal heat, when out side temp is 50 degrees or higher hot air, colder temps Luke warm, flushed radiator, heater core, new water pump, thermostat, actuator, any help would be appreciated
Thanks
kiwi_outdoors
If you had the heater core replaced, it does raise the possibility of damage to the HVAC internals, such as a blend foor or its actuator, or maybe an electrical plug has come loose.
