ThunderbirdJunkie
Bronze Supporter
30% less fuel with a 20% increase in cost, and 30% higher maintenance costs kind of cancel themselves out.
Just sayin
Just sayin
Just sayin
my minivan engine vs your crd. see which one is least expensive to own over 3 years
how about I chalange you to tow a 5000 pound trailer. That mini van gasser wrangler won't do it. I'd win you would damage your trans or engine trying it.
in my 2 door tiny jk yea i might have an issue.
how do you figure higher maintance cost? I change my own oil and it don't cost me any more than it would for a gasser to use the same quality oils other than mine may take a quart more of it. I can go 6500 miles on one oil change and that is the severe service schedule, for gas its 3000 miles. I spend the same $$$ on one oil change as a gas on two changes and I can go as long as a gasser can on 2 cheap oil changes. So I spend less time changing it too.
yes we have timing belts not chains, chains can and do break just not as often. Most recent smaller engines use timing belts. from what I have seen the 3.7 has a weaker valve train that is prone to failure too.
fuel is only more due to the oil companies messing with us. diesel is less refined and should cost less to make but in the US they say demand is high cus they keep the supply and demand as it is. Diesel also has more BTU per Gallon so you are gettin more energy for you money.
ThunderbirdJunkie changes his own oil too.
How much is Rotella+Bosch filter every 5k miles?
For ThunderbirdJunkie, 5k miles=Mobil 1+Bosch filter=$30
yeah thats what I thought..... many have towed heavier loads than 5000# with the CRD and one guy on LOST still got 19MPG towing over 5000 pounds!
So towing is one thing the CRD is better for than a Gasser![]()
So glad I did not get a CRD,have put 1 coil on mine,some oil changes&air filter.Have 196k miles on it,flog ricers,oil burners daily. Do not give a hoot in hell about global warming,whales,or goose stepping spainish ****'s.
yea. i enjoy my huge aftermarket. i didnt get the jk for towing. or passengers.
i also enjoy no problems.
the crd is junk. thats the issue. sure you might be able to tow, while it works
My CRD is not junk! I have had no big problems with it so far and it has never broken down on me. it is my daily driver and only vehicle. Its starts for me every day in all weather and carries my Fat A$$ every day where I need to go in comfort.
I got my CRD because I wanted a vehicle that had 4 wheel drive, was small, easy to handle and park, was commortable to drive, got decent MPG and could tow becasue I planned on buying a camper in the near future. The CRD was the best fit for my current and future needs.
There are just as many or more posts on forums about gasser Jeep problems as the CRD the only difference is there are fewer CRD's and for some less experienced mechanics to work on them in the states. If more of the folks in this thread were in europe where diesel is in 50% or more of the cars we would not still be discussing this.
Don't mind ThunderbirdJunkie, only 166,000 trouble-free miles
About 66,000 miles of borrowed time right?
for someone who drives a gasser you sure are pro CRapD
