4.7 swap
You can post more than one picture per page by the way
keep it from being 250 pages
Dunekj
Michigan
Yes just found this out ...sorry folks new to this stuff please bare with me.
Myke
USA
I hope you get this figured out. Could see this in my future if you do.
Honduras
Honduras
I have faith! You have no alternative, so dive in!!!
Why did #Honduras sell it? Unsatisfied??
Sent from my LG-K210 using Tapatalk
I sold it because the V8 swap was supposed to compliment the SFA swap that I never received
Rock Lizard took tens of thousands of dollars of my money and ran off with it without delivering a single thing. His excuse was that he needed to pay for legal fees for a child custody case (which, according to Springfield public records, only came out to ~$3K) I sued him and won, but the guy is already so indebted that I'll never see a dime of it.
Live and learn, I suppose. The V8 Liberty is still running without any problems, albeit under a new owner.
libordemise
CA
Sorry to hear that, I almost paid him to ship me a front winch mount bumper... Glad I didn't do it now,
libordemise
CA
In wondering... Even with the JBA steel front diff, would the 3.7L be enough to turn deeper gears like 4.88 and 5.13 etc? Would that Durango engine be better?
LOL yes its enough
check out Troys ( tjkj2002 ) build sometime
stock 3.7/ SFA'd/ 35s / 5.13s etc
With the right gearing a small motor can pull more than a large with the wrong gearing
Just like people running 32s and stock 3.73s and complaining no power and poor mileage
libordemise
CA
Yaaaa.. His is pretty awesome, partly inspired me to do my lift, still think about an SFA from time to time [emoji124]
Honduras
Honduras
The JBA diff will support 4.88, but not 5.13.
libordemise
CA
LOL yes its enough
That makes me wonder.. Is there a better rear axle that could bolt up in the rear to compensate for the steel diff+ bigger gears?
How much $$$ do you have?
I'm running a Ford HP44 up front and a Currie RockJock60 in the rear.
The issue is no rear diff is a direct bolt up besides the what is in there already and if you want to go above 4.56 gears(I would not recommend 4.88's in a 8.25,requires grinding some ring gear teeth) you will need to modify and then you will need to change the t-case for one that has a speedo port since the speedo is run off the rear diff via a AC signal generator(tone ring and sensor),then adpat a AC signal generator on the speedo port in the new t-case.
libordemise
CA
Oh! I hadn't expected to need a new t case, depending on what the replacement t case and potential axles would come off of I might be able to budget something like this, # since I can probably sell my current axles for a good price lmao
Oops. Re read your setup
So; what determines what axle and tcase I can use??
libordemise
CA
Also, with gears like say 4.88 what's an expected top speed decrease? How about 5.13?? Can I even take mine on the hiway if I did this lol
The TJ Rubicon RockTrac t-case and a Atlas t-case are about your only choice that is an actual upgrade with no mods needed besides driveshafts.I have a Atlas 4.3 in my KJ.
If your sticking to IFS you will not need lower then 4.56's since 32"(extreme 33") tires can can only be fitted anyways,you'd have to jump up to 34"-35" tires before needing 4.88/5.13 gears which will require a SFA swap,which would make a V8 swap much easier.
libordemise
CA
What a taank that would be..
libordemise
CA
So, to go lower than 4.56s you need a sfa?? Meaning the jba steel diff is only good to 4.56s?
libordemise
CA
Because the tires wont fit I guess? Even with my 3.75" lift?
