03GoingStrong
- Joined
- Jun 26, 2020
- Messages
- 119
- Reaction score
- 58
03 Liberty with just under 55K miles ... yep, 55K
Bought new in 03 and had fluid changed in transmission once, several years ago.
In the last year or so, the transmission had gotten pretty bad about engine rev before going into high gear. I overfilled the transmission by a few ounces of fluid and that seemed to improve shifting but the rev/shift delay into high gear was still there and it has annoyed me.
Don't know what I'm doing, but thought I'd give something a try. I got to thinking, well, wonder if the Transmission Throttle Valve Cable had become stretched or something?
So I checked the cable behind the throttle body and sure enough, there was a BUNCH of slack in the Transmission Throttle Valve Cable.
I don't know how to adjust the cable. So I thought I'd try putting a small zip-tie on the end of the cable to take up some slack.
Lo and behold, shifts improved !!! But still not "perfect". And there was still a good bit of slack in the cable. SOooo I put a second zip-tie on the end of the cable. And hot dang, not only did it correct the engine rev/shift delay into high gear, but shifts are better all the way up and down.
Wouldn't advise this as a fix, but the hack is working on my Jeep. Maybe there's a way to adjust the cable and proper procedures, or maybe the cable should just be replaced if possibly stretched ... dunno. In the meantime, I'll just enjoy a transmission that shifts better than it has in years and years.
