I went to advance auto parts (they sell carquest) and they have that compressor but no parts for it. Since it's not an emergency situation (yet) I've decided to get a shorter belt in order to bypass the ac compressor and keep it and the necessary tools in the Liberty.
Post in thread 'Belt just snapped..'
https://www.jeepkj.com/threads/belt-just-snapped.79002/post-794253
there is your shorter belt.
Thanks for the link
What I can't decide is which way to route the bypass belt? I've found a couple of pictures, I hope this routing will work since it doesn't require removing the pulley
The other way would need the pulley gone
I wonder which way uses the 82 1/2" belt? I guess I'll use a cloth tape measure and check each route. I'm really hoping that the routing in the first image will work, since it doesn't require the pulley to be removed. Who knows, I might save enough $ to buy a proper replacement compressor and fix it right before it becomes a problem! I just need to be prepared since it's my wifes car, and I can't have it broke down.
