AC/off on all settings!
flair1111
usa
Hey i just did the "tape trick" for my AC...read more about it here ..."http://www.jeepkj.com/forum/showthread.php?t=26491"....
It works great and i love the fact i will save tons of gas during the winter months, and also the cooler summer days using any setting I want. I just tapped the circuit starting on the #2 path and tapped it up with UPS packing tape all the way! Follow the link to see what I mean on that. No AC compressor turning unless i push the AC button!
Gige
Rijeka
Hey flair1111, my mod came in a bit late for you, but you can still check it on the end of the thread link you posted....
Cheers
Gige
JIMMY JEEP
United Kingdom
Be sure to run your AC at least once a week for 15 mins or so to keep everything oiled up and freely moving,or you might spend more on the fix than you save in gas.
That is 100% correct.Before they started having the A/C on for certian settings(besides helping defrost way better) the rate of A/C compressor pump seal failures was high,after the seals lasted longer,hence makeing the A/C run a little during the winter.
Oh and the MPG difference is so small why bother?
