Actual Lift Amount - Lets Compare Fender Heights
ckorch
Arkansas
Stock 2002 Liberty Sport 147k miles F 18.5 ...
F 18.5
R 19.5
looking to get some lift soon and will post new numbers once i get it on
After the jeepinbyal tommudd lift kit
F22.5
R23.5
TwoBobsKJ
Northern Ohio
F 18.5
R 19.5
F22.5
R23.5
Nice!!
Hurry with those pics!
ckorch
Arkansas
Yeah gotta figure where it went wrong.
Sent from my SPH-D710 using Tapatalk 2
Jo6pak
Left coast of WI
2 years and ~30k after installing Westway lift.
I've settled about 1/2"
Moog coils, KYB shocks.
Front= Boiler's .375" shims + .375" clevis adjustment
Rear= 2 extra upper isolators per side
df= 19.5"
pf= 19.5"
dr= 20."
pr= 20."
rbm92226
Anna, Texas
05 Liberty, Full Ironman LIft, jba uca's, 1/4" top plate, 3/8" clevis
Front driver side 23.00"
Front passenger Side 23.00"
Rear driver 22.25"
Rear pass 22.25"
Yayo0690
Venezuela
Daystar 2.5 lift have had it on for a year and is great. It was 159.00 off ebay, the front bushings are a little tricky but all and all it was a easy install.
I put a Daystar 1.5" lift in front on my Liberty, nothing in back, just to level it. I had to take it all out one week later because I needed larger front shocks. I was drinving on an uneven road nothing really bumpy and the shocks would travel to the limit and bump really ******* the strut and actually did some damage on the strut. How did you deal with that? Did you buy larger shocks?
This is how it looked after I put on the lift.
And this is how it looks now :(
there isn't any larger shocks, aftermarket yes like OME / Bilstein etc your issue is caused by the lift you chose to use.
More than likely it caused the shocks to blow, no bumpstops, etc
rawger
phoenix az
suspension height
04 renegade
2.5" skyjacker spacer lift installed at 55000 miles
265/70-16 Michelin LT MS
139850 miles now
just installed new upper A arms with ball joints from Quadratech
my upper arm bushings were completely gone
22" both front
20.75" LR
20.50" RR
still rides and handles good
greene
Texas
With everything finished.
23” all the way around.
greene
Texas
LOL, That is the wife’s she is getting OME springs and Bilstein’s all around with no additional stuff. Just to give her a nicer ride and to keep her from stilling my jeep. :cheers:
Armysniper
Space Costs FL
97,399 miles 04 sport
17" front
17 1/4 rear
Lifted on 8/31/2013
Ome 927 front springs
Ome 928 rear springs
Front Ranchos
Rear Ranchos
3 conduits per side
22.5 front
22 rear
45 miles on the lift:High 5:
Armysniper
Space Costs FL
17" front
17 1/4 rear
Lifted on 8/31/2013
Front Ranchos
Rear Ranchos
3 conduits per side
22.5 front
22 rear
Update, added a 1/4" top plate in the front.
Now 23" up fron:Caffeine:
John3seventeen
WV Panhandle
You can add two Iso's to the top of the springs in the rear they will add 1/2" each and that should put you at 23" front and rear.
