- Joined
- Dec 17, 2006
- Messages
- 10,612
- Reaction score
- 42
It will actually cause all the cylinders on that bank to misfire but 1 may misfire worse then the others,just enough to trip a specific cylinder code,due to a slight(or major) problem with that specific cylinder.A slightly plugged injector,lower compression,bad rings,mis-aligned rings,poor cylinder wall condition,out of round cylinder,to big of bore for the piston/rings(it happens on remaned engines a lot),improper valve sealing,weak coil,bad spark plug,bad coil driver,wiring issue for coil,and many more things can cause just enough difference to make 1 cylinder actually misfire bad enough over the others on that bank to trip the MIL while the others will not.All engines regardless misfire all the time(not all the time but misfire on occasion due to freak causes),even in perfect running condition but it's not enough to feel or meet the requirements to trip the MIL.How does a multi-cylinder cat converter trip a cylinder specific misfire?
