Backspacing question!
Weaver
Canada
So the factory backspacing is 5.5 from what I've read, I'm getting a OME lift so I'm gonna be putting 245/75/16 wheels n tires on it but my question is what looks better 16x7" with 4" backspacing or 16x8" with 5" backspacing, pics would be great thanks
Red07KJ
BC
+1 ^
I'd stay stock with the 16x7's unless you have a big ******* for some new/different wheels...
If you've got money to burn then do whatever floats your boat.
sevenhelmet
Ridgecrest, CA
I have 16x7" soft 8s with 4" backspacing, and I get mild rubbing on the fog light doors with an OME lift and bigger tires. I really like the wider stance though. There are some pictures of my Jeep floating around on this site somewhere, I'm at work right now so I can't post any.
Weaver
Canada
Okay thanks for the advice I'll go with the 16x7 cragars, and sevenhelmet what size tires are you using that gives you a bit of rubbing?
sevenhelmet
Ridgecrest, CA
I had slight rubbing with 235 70R16s on a stock suspension, but I have slightly bigger tires now that she's lifted. I emphasize SLIGHT rubbing, nothing 5 minutes with a heat gun can't fix.
Weaver
Canada
Ok I'm getting 245/70/16, it will be on a stock suspension most likely for maybe a month or do you think I will get alot of rubbing with that size
Honduras
Honduras
I am running with 3" backspacing with a set of 33x12.50s. This may seem excessive, but I wanted to maintain a reasonable CoG with 6" of lift. It handles great, but it kicks mud, dirt, and rocks all over the damn place.
I'm getting a set of steel flat wheel fenders fabricated. it's only a matter of time before I kick a rock straight up and into my windshield.
I'll post a pic of what it looks like straight on in a bit.
Honduras
Honduras
What 3" backspacing and 33x12.50 looks like..
[/IMG]
Weaver
Canada
[/IMG]
nice look but a bit more then im going for, but it gives me an ida how my backspacing will look with 16x7 245/70/16 4" bs and a OME hd lift
Looking forward to getting it done soon, Ill post before an after pics
Honduras
Honduras
You will still be inside of the wells with 4" of backspacing.
J-Thompson
just south of doucheville
Don't waste money on either
Wheels or 245/70's if you plan to lift
Best fit/look for a lifted KJ
245/75 R16's on stock alum. wheels
gives a "stock" look until you park next to a stock
KJ ,then you notice
The $250+ saved is nearly 1/2 the cost of a Detroit locker
which will give you more ability than the lift and tires combined
Weaver
Canada
KJ ,then you notice
Alright Im gonna hold off on the rims, but Im gonna paint my stock ones and I have to get the 245/70/16 cause I dont have the money to lift it then get tires and I need to get tires before this winter.
