Best 2" lift kit
Nutty
Looking to put larger tires on my 09 KJ. Not really a trail guy. Mostly for cosmetic purposes and a little more clearance in deeper snow. Any recommendations on a budget friendly lift.
Nutty
2" to 2.5"
Nutty
Correction- KK
2" to 2.5"
Does not matter if you are or are not a trail guy, same lift applies
OME springs and then a full set of OME or Bilstein shocks for a 2.5 inch lift
If you would like the numbers we can give those to you.
But that is it anymore , OME makes a great product, have installed over 50 Liberty lifts using OME and have personally ran them on mine at one point
About 800 or so for springs, shocks, of course would need bumpstops etc.
budget and lift do not go together unless you just want to lift it and let it sit in the driveway
Nutty
Well within what I was looking to spend.. Thanks for the recommendation.
OME 927 front springs with 90009 front shocks
rear OME 731 springs and N132L rear shocks
Teraflex front bumpstops
can use 2 hockey pucks per side in the rear bolted down to the lower spring perch for rear bumpstops
Now on the KKs due to the different style of rear suspension it will pull the rear of the body over some
due to the trac bar
Check Jeepinbyal for everything
Nutty
due to the trac bar
Thanks for the numbers. Lookin forward to starting this little project with my daughter as this will be her vehicle in a year.
