Cross drilled rotors are actually worse for braking performance,less metal ='s less braking.
The only reason drilled rotors came to be is from drag racing were every ounce counted in weight reduction.That is it,they drilled holes in the rotors to save weight.There is no other benefits period.The import idiots adopted them because they "look cool".
Slotted rotors can have a effect but unless your racing you also don't need them.Good way to trash pads on a daily driver.
Holes and slots reduce wear, slots increase brake grip,holes and slots eject water and can reduce hydro planing. Wearing the pads out sooner can be possible if you use cheap brake pads. Holes also expel the "gas" from the brake pads to stop them from wearing faster. Multiple sources all say the same thing. They work great. Unfortunately I did not break in my first set. I noticed a big difference when I switched to them the first time. Yes they can wear the pads down faster if you're going fast but if you're driving normal, they actually have a ton of benefits. Technology has changed and while cross drilling may not be necessary anymore, it still helps
While stock rotors have more surface area and while the cross and slotted has less because of the slots and holes, more is not always better.
