Hey, i've got a few more questions
When i got of of my Liberty today i saw a sticker inside the door jam, which had all of my tire info on it. It said my stock tires are - P225/75r16. After finding that out i went to a tire conversion site and if the sticker is right..my tires would go from 29.3's to 29.5's? Am i missing something or is this right?
The reason is was going to switch is i go off-road sometimes with my friends. They usally go mudding through some pretty thick stuff and the only time i actully go is when there's just a tiny bit of thin mud.
I was going to switch to these off-roading tires from my stock tires in hope of being able to go though some thicker mud, i only have 2WD though.
Would switching to these tires even be worth while? Keep in mind the tires are free..
Thanks for all the help..this forum is the best
- Kolton.
I am not trying to be an a$$ so dont take it that way
2wd is for on road use and really does not belong off road no matter how mild it is
if you are playing in mud then my guess is that you are blasting through it at a high rate of speed ,remember that for me 10 mph is way to fast for off roading
when you do this it is just way to dangerous get going side ways and clip a tree? a person? another rig? roll your rig?
none of these will end good
I can tell you that clipping a tree going up hill at 5 mph destroyed the fender on my TJ would have been much worse in a KJ
The best thing you can do if you want to go off road is sell the 2wd and get a 4wd
a stock 4wd will go further off road than a lifted and MT'ed 2wd
and come out with almost no damage ,other than a few scratches
sure you can put those tires on and blast through the mud and go a little further than before but get a 4X4 and you can really go off road
I have a picture of my wife in a stock KJ with AT's going up and down hills so steep that the front and rear bumpers drug the ground
front hit going up ,to steep, and going down ,also to steep
same for the rear
a 2wd would have never even started to go up ,no way to get a running start as you would have crashed into the dirt ,remember that the bumper hit
then with out the help of gears to very slowly go down the other side when you got there you would just spin your tires trying to push your way off the ground ,go to fast and you will roll
sorry if I sound like a jerk but fact is 2wd's belong on road
