SXYFSH327
HEY JEEP PEEPS So I'm just looking for some input and opinions about Blue Devil AND the proper way to use it
What leak are you experiencing ? Is it a coolant leak?
Good to know!! Thank uAll the water system sealers I've ever seen are horrible, they block the radiator and heater matrix and create more problems.
Hello, I used it for a small head gasket leak on a 2010 Liberty. Its been over a year now and around 10,000 miles ..works perfect!! Couple of tips..use a by pass hose so it doesn't go through heater core..and remove thermostat prior to adding it...Was having small levels of coolant leaking and had a mis fire code coming up..so It would not pass state emissions.HEY JEEP PEEPS So I'm just looking for some input and opinions about Blue Devil AND the proper way to use it
So he actually DID put it thru the radiator but the thermostat should have came out from what I'm hearing...is that why it only overheated when driving it but not when it idled for Hal an hour??The "proper" way to use any product, is according to the maker's instructions. If you want to give it another go, thoroughly flush the system then apply the correct amount amount strictly in accordance with the directions on the bottle. Good luck!
It was originally developed for the cadillac for their north star engines. long story short the metal was porous and would have coolant leaks. That was their fix for it....I remember that GM branded Barrs Leaks fiasco. The reason was so they didn't have to bother with minor leaks under warranty, so recommended adding it, almost as a service item. At least 15 years ago it was realised it was all a terrible mistake, so the advice was quietly dropped. Read any GM forum and the received wisdom, loud & clear, is, if it's not too late, flush that muck out.
