Have you considered the possibility that you might have a dropped valve into a cylinder? (although this doesn't explain the oil loss)
One of the possible scenarios I threw at you earlier was if the timing chain or related went out, and a piston hits a (now out of time) open valve. That can do damage to the valve, the piston, and to the cylinder wall if the valve snaps off.
A dropped valve seat can happen with the 3.7 and 4.7 engines. What happens is the hardened seat comes loose from the head, and it can slip down and wedge the valve open. It's also one of the causes for rocker arms throwing off. You will see if something is out of place when you go scoping around.
The endoscope is will be delivered shortly according to amazon, hoping for the best :help:
What brand did you get? Does it come with a mirror attachment so you can look at the valves and head?
I got this:
DBPOWER 8.5MM 2M 2MP Cellphone Endoscope for Android System with OTG and UVC Function & Compatible with laptop (USB adapter included)
And no it doesn't have a mirror attachment :favorites68: You guys gotta remember I'm a noob, I don't know these things :help:
Found the exact source of that oil leak yet ?
I just looked at the amazon listing.
It'll come with a mirror attachment.
I've been curious to see how well those Android scopes work. Hopefully you'll have some show & tell photos or video?
If a valve dropped, snapped and broke off, that will be obvious.
A loose/dropped valve seat, you want to look for signs of movement or gaps between the seat and head. Have someone turn the engine over while you watch for a valve seat to slide down as the valves open.
What the heck is that? Did the piston self-destruct? There's a weird almost tooth looking thing in the fist two pics.
I think the tooth looking things is the expander ring. That piston appears to be completely trashed. Something really let loose. Time to pull the heads and have a real good look.
It looks kind of like a one of the piston rings. There's several on each piston, one kind of looks like tooth thing. IMO it looks shattered in their too. But I'm on my phone squinting.
Edit: this was dropped down the cylinder through the spark plug opening right?
