Took the Jeep to get brake light turned off in order to get state inspection done. This is what I was given from mechanic. I can’t find a non abs master cylinder anywhere. Or atleast not specified. Only ones that come up look the same as currently on. Is this right? Any where I can get a NON ABS cylinder? Any other solutions? Any other possible and likely causes? Not to doubt a professional but feeling hopeless at this point.
Background information: The master cylinder was replaced a while ago but then other issues arises so the Jeep sat for a while until recently. Did not notice the light being on when originally replaced but definitely possible. There seems to be zero problems with it so the mechanic very well could be exactly right with it just being an electric issue not turning the light off. But Is it possible the master cylinder is just bad?
