Brake Light stuck on. Help
alr61397
Took the Jeep to get brake light turned off in order to get state inspection done. This is what I was given from mechanic. I can’t find a non abs master cylinder anywhere. Or atleast not specified. Only ones that come up look the same as currently on. Is this right? Any where I can get a NON ABS cylinder? Any other solutions? Any other possible and likely causes? Not to doubt a professional but feeling hopeless at this point.
Background information: The master cylinder was replaced a while ago but then other issues arises so the Jeep sat for a while until recently. Did not notice the light being on when originally replaced but definitely possible. There seems to be zero problems with it so the mechanic very well could be exactly right with it just being an electric issue not turning the light off. But Is it possible the master cylinder is just bad?
turblediesel
memberable
Alaska
Internal piston seal failure can happen, but it was replaced recently? Maybe a bad rebuilt or junkyard replacement?
Maybe try a rebuild kit.
Billwill
White River, South Africa
What Year/Model is your Jeep?
I hopefully have the Logics for that model and can advise you....I really do not see what the Master Cylinder's resistance has to do with this problem!
Deb'nKJ
I really don't understand the diagnostics (but that might just be me.
I'm surprised KJ's have hydraulic brakelight switches but even more so that it's mounted on the MC.
Never known a switch to fail "on", my 1st suspect for that fault would be the parking brake switch being stuck.
