I just finished speaking with my buddy Richard about the problem. He came over and took a look at the situation. He said he doesn't feel comfortable about welding onto the end of the broken exhaust bolt for various reasons:
#1 is because the angle of the working area at the exhaust manifold mounting surface is kinda in a "blind spot".
#2 is because he doesn't know how the power of the welder (the electricity flowing thru the engine block) will effect the vehicles electronics.
#3 The head is made of aluminum and when the heat of the steel welding together could melt the aluminum possibly cracking it due to extreme temperature differences.
He mentioned a couple other things to consider that I had not even thought about. Anyhow, Richard may just own a wrought iron fence welding company, but he has a small machine shop also where he builds custom parts for ANYTHING, whether it's part's for a big V Twin bike or an intake manifold made from a sheet of alloy for a V8 car.....the guy's good.
So he took the exhaust manifold home with him and here's the plan:
Tomorrow he will take the exhaust manifold to his shop.......he's going to use the manifold as a template to construct a jig out of hardened steel, he's then, going to install the jig in place where the manifold should go. The jig is going to have a short tube welded to the end of it directly inline with the broken bolt, kinda like a guide tube so the drill can dig it's way straight into the broken bolt. My job tomorrow is to find a quality set of "reverse twist" drill bits (I did not know these existed) and match up the correct sized bit with the replacement exhaust manifold bolt. I am going to take that bit down to our local tool & die company and have them cut, sharpen and retemper the bit. Basically they are going to shorten the bit. In the mean time, while the bit is being dealt with, I will be busy removing the brake master cylinder and booster as well as the anti lock brake components and the steering shaft.....and hoses....and wires....and, yeah, whatever else is in the way. He is going to use a certain kind of drilling tool (I forget what he called it) but he say's it can drill holes at a 90* angle (something else I've never heard of). He said, "With any luck, the reverse twist of the drill will eventually unscrew the busted bolt on it's own and we (he) wont have to drill the entire length of the bolt. Keeping my fingers crossed.
I'll update our success or failure once it happens.
