Can the KJ pull a car on a car trailer or isit just to small
hyde
there is slip on one wheel (like in snow) that will just spin freely....w/o the others spinning
Even on 4Lo ? I thought it locked all four wheels, but from this I figure it only locks front and rear but not sideways.
Correct, if you do not have a factory limited slip then only 2 wheels(1 front and 1 rear) are guaranteed to spin in 4low and 4 part time. 1 wheel total will spin in full time, but it can either be 1 front wheel or 1 back wheel.
Guyute1210
Wildbill said:
YES!!!! As long as you have the Factory Tow Pkg. I towed my YJ on a 1700 lbs car hauler from SWFL to Tellico and it worked great. Only problem was when I got close to Tellico with all the mountains, I ran out gear. (too high) I just unloaded and drove the YJ the rest of way. Temp Gauge never went past half way which is where it sits all the time.
Wildbill
Can you explain this: Only problem was when I got close to Tellico with all the mountains, I ran out gear. (too high) I just unloaded and drove the YJ the rest of way.
What is you ran out of gear?
Wildbill
Port Charlotte, FL
Guyute1210 said:
Wildbill
My gears where to high.....It caused the RPMs to go way up into 4000 range and I was barely moving. If I had a lower gear ratio (higher number) it would pull alot easier.
Wildbill
