Coil 6 Insufficient Ionization, Multiple Cylinder Misfire, Fuel Injector 4 Circut/Open
candy11024
2nd Tank of Cleaner, no luck.
New Sparks, no luck.... although it seemed to run a *little* smoother, and the misfire codes went away.
Only remaining codes are:
P0204 - Fuel Injector 4 Circuit/Open
P2317 - Ignition Coil 6 Secondary Circuit - Low Ionization
Still suffering from basically falling flat on it's face past 2100 RPM, and idling poorly.
My Jeep has similar issues,Does your Jeep run great when the gas light is on as soon as I put gas no runs good no more
blackhawk
Venezuela
I was randomly dealing with this video for around 6 months but in coil 6. The issue was in the connector of that coil. The pin was a little bit open.....
I close it with a needle and solved the problem. Hope this helps
