jsc7002
tow straps and recovery straps are the same if you ever look at the, I bought one that is rated for 10000# but its breaking strength is 20000#
Holy hell, someone who acutally knows something about load rating equipment.
You can run your tires EASILY over 2x the "max rating" , but I'm not telling you to do it, nor would the company I work for. Liabilities are a *****.
Hey guys, just thought I'd give an update on my quest for MPG in my wife's jeep.
We had 2 tanks of 20.4-20.6 and finally this tank we recorded a 22.1 MPG combined. She drives 50% city/ 50% highway. We are damned pleased, according my my scangauge we are averaging 26-27 mpg on the highway.
Mods we did:
Cold air intake
fully synthetic oil
50psi in all tires, tires brand new
not idling in prolonged periods while waiting at stoplights
I discovered that I could get decent MPG numbers, city and highway, by pumping my tires to 40PSI. Seems to be a good number. I'm running the same in the WK now... might increase it a bit due to the extra weight of the vehicle. And no I haven't noticed a bit of odd tire wear.
Tires are rated for 51 psi.
As for all the uneven tire wear BS, I've got a pair of tires on my accord with 87K on them rated for 60K. They are rated for 44 psi and have been at 60 psi for 4 years with no uneven wear.
Burst pressures on modern tires are well over 200 psi, you have been repeating too many myths which are not true. Low tire pressure leads to fatigue and blowouts, NOT high pressure.
I'm driving a 2004 Liberty 4x4 gas engine.
oh well engineers they know it all I guess
Oh an I was in the tire business before you became an engineer it looks like
I run with about 50 lbs of gear in the rear and have a push bar up front. When I tried taking my silent armor tires that are rated at 45 cold to 40 it was quite a bit stiffer, felt all the bumps, occasionally a shudder through the wheel on pot holes, but also got way better mileage. Today I leave them at 37.5 but know I am sacrificing mileage, butt not my tail bone.Did you get a stiffer and bouncier ride??
Right. People like me? Oh you mean Educated beings, aka a Tire Engineer. I've been an Engineer since 1976, what the **** have you done?
We put warnings on tires for idiots like you, obviously they are needed.
If you seriously think tires will self implode at the side wall max, or even OVER IT, you sir, are an IDIOT.
I personally don't think it's a good idea to go over the posted rating. But sometimes there are abnormal circumstances, and it would probably cross my mind to go more than maximum allowed ratings for a short - very short - time only. Not ever on a 'normal use' basis. To me, that's dangerous.
I keep mine at 34 PSI. It's the only PSI I can run where I don't get a low pressure alarm in the morning, and a high pressure alarm in the afternoon.
