Btownpreacher
- Joined
- Nov 13, 2022
- Messages
- 126
- Reaction score
- 102
i just found upon further inspection that the liner in cylinder #2 is cracked from the impact
I thought it might be, that's a heavy impact. I would definitely replace the rod on that cylinder too.i just found upon further inspection that the liner in cylinder #2 is cracked from the impact
CaptainDean on LOSTJEEPS has an excellent thread with many photos of CRD guts.Does anyone have a thread they can recommend that has info on how to rebuild the CRD engine? Either here or on lost jeeps? I’ve got the engine down to the block, and I’ve just removed the block. I want to find some resources before I open the bottom end
You may want to check the alternator pulley have some one start it while you watch it if it's like my 06 you won't believe what you see .I’ve mentioned this before in previous posts, but my 05 CRD has developed a bad rattling noise. It’s gotten drastically worse over the weekend and after inspecting it today it sounds like it’s either the oil pump or the fuel pump. Since I’m still getting oil pressure and my engine hasn’t blown up, I think my cp3 is dying. From all of the symptoms that I’ve read about it send to match well. Any idea on how to prove/test this?
That was a video but apparently it only took the cover photo which you can see how much movement is there if you look at the blurry out lineThe pulley on the alternator I mentioned
Did you get it rebuilt in the end?The engine rattle turned out to be a failed harmonic balancer. Made terrible noise but made no difference to the engines performance. Unfortunately I never found out until after my engine grenade-ed
