sasquatchms
- Joined
- Feb 22, 2014
- Messages
- 27
- Reaction score
- 0
Depending on where the leak is, you might be able to bypass the cooler using a series of small hose barbs and clamps, but to access you'll be doing much of the work required to install our kit. Getting the factory elbow off (and especially back on) is a huge pain in the butt.HI on my 2005 CRD the EGR cooler is leaking antifreeze badly. I am ordering the delet kit for it. Can I bypass the coolant lines temporaily to get it back on the road until the kit is delivered ? Thanks .
Hi Chris
No, it didn't trigger any warning lights at all. BUT remember that I've had the GDE FT Ecotune installed for over 2 years now, and that tune also reduces EGR function to a minimum and prevents the system throwing codes/warnings related to that function, so I can't say what it would do on yours. I can say that the guys in Aus who also have the export spec like ours and who simply blanked off the EGR didn't have any dash lights triggered. I'll have to dig out the receipt; the kit sat in the shed for a few months after I bought it before I got round to having it fitted.
Update: ok Chris, found the info. Cost of the kit in Sterling was £146 plus the sterling conversion fee of about £4.50. I had it sent by UPS (I think) and that added about £22.00 which included import. I've rounded up the odd pence! Hope this helps.
Adrian
Look forward to hearing!
I know about stuff happening, so I hope the issues or problems are sorted. Good luck.
Adrian
Hey Chris,
No need to be concerned. International economy shipments to the U.K. can take 3-6 weeks for delivery, and it's also the holiday season. We are well within that time frame for delivery. That said, I am personally keeping an eye on your shipment.
Adrian usually requests FedEx when he orders from us, as that is his preference, but he also pays extra for that service.
More shipping info can be found here: https://shop.sasquatchparts.com/shipping/
Thanks again for your business.
Seth
Thanks for your feedback Chris. We will take your suggestions into consideration.
I am confident your order will arrive on-time and undamaged. We take great care to pack all shipments so they arrive in one piece.
The fine print is more-or-less boiler plate and is only there to protect us from fraudsters. All shipments are insured for loss and damage.
Thanks,
Seth
Chris, just wanted to let you know I made some changes on our web site to make our international shipping options a bit more clear.
Did you get a chance to install the kit yet? If so, I hope you're enjoying it so far.
Do you think this EGR Tube could be responsible for the sudden lack of boost ? It would also explain the clung clung noise if that pipe was loose.
Chris,
It's possible. The exhaust-side EGR tube is known to crack, break and leak.
When doing the Stage 2 install, a tip is to secure our manifold cap using the v-band clamp from the intake side EGR tube. The exhaust side clamp tends to be in pretty bad shape after being exposed to high temps and corrosion over the last 10+ years. The intake side clamp tends to be in a lot better condition because of the lack of exposure to high temp exhaust gases.
Is that Exhaust EGR Tube fitted to anything else between the Exhaust manifold and the EGR Valve?
There is a small J shaped bracket that the tube sits in on the back of the cylinder head. Pull up on the EGR tube and it will pop out of the J bracket. The bracket can stay, no need to remove it.
